I have an hth 5 way drop kit. Levels are CL 5 ph 6.5 alk 40. Cya 70. In the last 24 hours I added in order 3lbs baking soda, 4 lbs borax now 5 gallons bleach.
+ Read the Best Guess Chlorine page, linked in my signature
+ Hold your chlorine level in the DARK yellow range, till you have the K2006.
+ Unless your pool is concrete, do not add any more baking soda or calcium hardness.
+ Use borax (Walmart detergent section) to raise pH to 7.2 or so.
PoolDoc / Ben
How much borax should I use? pH is 6.5 for a 35k gallon pool. Vinyl liner. I also have white foam in the skimmer & a lot of cloudy floaters. Should I scoop out the foam? I am also running my cleaning robot thanks for replying Pooldoc![]()
35k gallons?
Try 2 boxes at a time, added SLOWLY to a skimmer with the pump on. Drop back to 1 box once pH gets above 7.0
PoolDoc / Ben
Hey Ben I posted this somewhere else bc I couldn't find my way back but here goes
I think I am having the same problem. I am new to the forum ( well posting anyways) I have a 35k+ gallon L shape boy cya is 65-70 and I can't keep the CL up I have used 45 gallons of cheap bleach in 3 days. Readings are CL drops from 5 to 0 overnight. Ph is going between 6.5 & 7.2 I have used 6 boxes borax in the last week also. I have 3" chlorinating tabs running constantly thru a chlorinator. Alk is 50. Using 6 way hth kit & strips. Strips say stabilizer is low but hth says high? Very confused. I am having surgery Wednesday & need to get this in order any help is appreciated.
Hth 6 way
CL 0 just added 5 gallons bleach tested its bright yellow after 1 hour
Ph 7.2
Alk 70
Cya maybe 65 Can't test anymore I ran out of drops. ( the bottles is not proportionate)
Thanks so much for having this forum I am going crazy & everybody is driving me crazy asking when it's going to be ready
