Results 1 to 4 of 4
Thread: Help for my neighbor
    Apr 2012
    Ohio
    Default Help for my neighbor
    My neighbor called asking for help. Their pool is green. My Taylor kit says FC is zero, TC is zero, Ph is 7.0 or less, ALK is 80, Cya is less than 30 if any at all, the dot is very visible when the tube is full. I added 3 gallons of Walmart bleach that i had on hand but im wondering where to start. He says he added 5 bags of shock a few days ago, and yet FC is zero.
    The pool is a 24 foot AG. Im guessing about 13,000 gallons. Sand filter.
    Where should I start?
    17,500 Gallon above ground, Hayward 150 pound sand filter containing 75 pounds of Zeobright, 1.0 HP pump, Rheem natural gas heater
    My results are generated from a Taylor K2006 kit.
    27' round 17.5K gal AG pool; Bleach; Hayward 150 pound sand filter; Hayward 1.0 hp pump; 12hrs; Taylor K-2006; well; summer: ; winter: ; iPad; PF:6.9
    Ontario.
    Default Re: Help for my neighbor
    Best starting place is here:
    http://www.poolforum.com/pf2/showthr...You-have-ALGAE!!!
    You have the first part covered with the Taylor 2006 so you can measure high chlorine levels. Before hitting the water hard with chlorine, check that the PH is in the 7.2 to 7.8 range - more info on this in the link.
    After that, it is a matter of killing the algae with chlorine. With a solid green pool, this will take a LOT of chlorine. A few bags of shock, and 3 bottles of chlorine will make a bit of headway, but it gets used up very quickly as it kills algae, then the algae just grows back. Use the cheapest chlorine source available, likely the bleach. The bags of shock are just a more expensive way of delivering chlorine.
    You want to get the chlorine level up to shock+ level and hold it there until the water is clear, don't back off or the algae will just bounce back. At CYA of 30, that is 15 PPM. For a 13k pool, 3 gallons of 6% bleach is 15 ppm, so what you put in would initially achieve that, which would be used up PDQ in a green pool. Usually it is good to add the chlorine at night, check the chlorine level 2-3 times a day, adding bleach as required to get the level back up to 15+. Please do not let the neighbour be cheap or shy with the bleach, better to run a higher level than letting the level get lower, the pool will not be harmed.
    After the green is gone, the water will be cloudy, and I find I need to keep the chlorine level up high until it goes clear. At this point, there will be a dead algae on the bottom of the pool, which a sand filter may just pass through. I vacum it to waste down the drain.
    http://www.poolsolutions.com/gd/best...e-chart.html#a
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    BigDave's Avatar
    Jul 2010
    New Jersey
    In addition to Spensar's sound advice; I'll add: Encourage / Insist that your neighbor register here, buy a K-2006, and understand everything you're doing to help. Unless you want to be a pool service.
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
    Apr 2012
    Ohio
    I couldnt agree more. He loved my kit and has the website, he should be joining soon. This site is great and has helped me many times.
  1. Neighbor with Yellow water after adding acid
    By DougM in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-27-2012, 11:15 PM
  2. Helping neighbor with pool
    By jilted in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-07-2012, 06:21 PM
  3. Neighbor has cloudy pool after 10 days of BBB, sudden dip in pH, TC
    By The Raddish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-27-2006, 01:50 PM
  4. Stains from neighbor's fireworks
    By smokeygrl in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-20-2006, 09:35 PM
