Results 1 to 10 of 13
Thread: Opened for first time with old loop loc mesh cover green swamp
    lstinthot is offline PF Supporter Thread Analyst lstinthot 0
    Aug 2011
    Default Re: Opened for first time with old loop loc mesh cover green swamp
    I would not use the "why not its was already in the shed" method. I have stuff still in the shed that I no longer desire to have in my pool after reading on this forum. Sounds like you need to start with getting a good test kit, drop based Taylor. http://www.poolsolutions.com/testkits.html talks about the test kits. I have the Taylor 2006C. I would think as long as you are circulating water and you are keeping your chlorine levels in the right range you will see some improvement until you can get the filter changed. I would not use any tabs until you know what the stablizer level is at. The couple of pools that I took from swamp to clean were swamps due to high levels of stablizer from always using stablized Cl` and low levels of Cl`. Liquid bleach or Liquid pool shock from BJs or Costco (BJs around here has box of 4 1.5 gallon for $13 where pool store wants $13 for one 1.5 gallon jug) seems to be the cheapest. Look at best guess guide to determine chlorine levels once you know the stablizer level. It may take a few days or weeks to get it clean, especially if you do not keep CL` levels right. Its really hard to help with out a good set of test results.
    ~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
    May 2013
    long island
    The stuff in the shed did zippo..lol....oh well..
    I am kind of letting it go until I put the new filter in. I don't want to waste more chemicals.
    But I did a test...same...
    Chlorine zero to low ..not sure why. What is a stabilizer level? All the shock in the world won't get me a chlorine reading it seems..
    PH and Alkalinity Normal
    Cyanic zero to low
    Hardness zero to low
    Will stick with the strips for now I have 40 left. Don't I have to test the morning each day I want to go in?
    My dad is a retired chemist. He said
    the test is more accurate when done by machine (still uses color for analysis, but it’s done using a spectrophotometer which doesn’t rely on eyesight),..so drops or paper still rely on looking at a color.
    BigDave's Avatar
    Quote Originally Posted by Gretzky99 View Post
    ... Will stick with the strips for now I have 40 left. Don't I have to test the morning each day I want to go in?
    Throw the strips out. They are not better than nothing, they are giving you an excuse to put-off buying a test kit that will help. I'm sorry but you dad is wrong here, the strips are innacurate and unreliable whether read by eyes or machine. FWIW you can tell your dad that (with the exception of pH) the tests in the Taylor K-2006 are not color matching, they are titration tests and the results are quite clear.
    May 2013
    long island
    Yes I will go with the Ultra Loc II with the panels as long as it doesn't turn the water green upon opening..why should I get the loop loc solid with a pump? the pump will proabably break many times and why do i want to be outside pumping snow off my pool when my driveway is full of it?
    DE 3620 Hayward. 16x36 Inground rectangle (1995). 7.5 ft deep end 3.5 ft shallow. loop loc cover with mesh panels
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    In retrospect, for me, pumping out the cover is preferable to opening to a swamp that takes me a week to totally clear. I'd probably go with the mesh panel cover next time, just pointing out the options.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    Another option is to not cover the pool at all. I no longer cover mine and haven't for years because I hated the hassle of dealing with a cover. In the fall, I just scoop out leaves. By the time I close my pool, the leaves are already off the trees. I shock the pool and adjust the pH to around 7.8 or 7.9 to allow for some drop over the winter, lower the water level a little, disconnect pump, etc. and I'm done. I do get a little dirt in the pool over the winter, but that is easily vacuumed out in the spring. The water stays clear. I do open the pool pretty early because our temps get hot pretty quick and I want to be able to start chlorinating so algae doesn't get started. This works for me. I don't ever plan on using a winter cover on my pool again. Just wanted to throw this out there as an another option for you to think about.
