Results 1 to 10 of 13
Thread: Opened for first time with old loop loc mesh cover green swamp
    May 2013
    long island
    Default Re: Opened for first time with old loop loc mesh cover green swamp
    So the chlorine tablets aren't fighting the algae? I need to use more liquid shock daily? I'm not sure if it's 8ft or 10 in the deep end so it is probably between 20 and 30,000 gallons.
    I couldn't figure out the calculator. It said I need one gallon of bleach to get it up to 3ppm?? which is the ideal level?
    DE 3620 Hayward. 16x36 Inground rectangle (1995). 7.5 ft deep end 3.5 ft shallow. loop loc cover with mesh panels
    The ideal chlorine levels depends on how high your CYA level is. Take a look at the Best Guess Chlorine Chart in my signature below for more about that.
    May 2013
    long island
    I don't know what the chart is supposed to do. If I don't dump something else in there my readings won't go up from zero or zero - low.
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    My advice to you is this.....read all the stickys in this forum and take the time to really understand the chemistry of a pool and how each number affects the other. Once you understand that, just follow the BBB method. Get a good test kit (Taylor 2006c) and whack away with the chlorine. It's simple but difficult at the same time until you understand the process.
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    I too have a loop-loc mesh cover, this is my 2nd season with it. My pool has been a swamp both times I opened it. Previously I had a regular solid winter cover, held down by water bags. I got tired of pumping off the cover, and cleaning off the leaves. That's why I went with the all mesh cover. Do not replace your old cover with an all mesh cover. There are 2 other loop-locs you can buy, one has a couple of mesh panels that let water through, the other is a solid cover with a pump. Either of these will prevent your pool from turning into a swamp over the winter.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
