Results 1 to 3 of 3
Thread: Spongy ground
    May 2013
    Alabama, USA
    Default Spongy ground
    We are trying to get our ground level to put up a 30ft round pool and we have areas in the ground that is spongy.
    I know the ground here was wet due to alot of rain this year, however it should be dry now. Could we have some other kind of issue underneath where we have dug down to? If it is just wet ground, putting some finely crusher mix rock in the areas and packing it down into the dirt would that help? The top layer of grass and about 5 or so inches of dirt has been removed for about 5 days now with no rain, and still have spongy areas.
    Please help! Ronda
    Default Re: Spongy ground
    Ronda,
    Do you live in an area where the water table is high? I really can't help you with your question but just wanted to pop in and say hi and welcome you to the forum. Hopefully someone will have a suggestion for you.
    May 2013
    Alabama, USA
    Unhappy Re: Spongy ground
    Thanks for replying watermom. Hope someone can give me some answers soon.
  1. Spongy Ground
    By bradatkins in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2012, 01:26 PM
  2. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  3. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  4. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  5. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
