Thread: Need help leveling land
    May 2013
    Wv
    Default Need help leveling land
    The ground where we decided to put a 14ft x 48 in intex pool was on a slope, so I dug out (by hand) the high side to be even with the lowest side. After setting the pool up, the water still runs downhill by about 2-3 inches. I have already took the pool down and re-dug twice, all with a level. Still runs downhill. Can't afford any fancy levels like a transit. Any ideas?
    Jul 2012
    Mexico, Missouri
    Default Re: Need help leveling land
    A 6ft 2x4 and a 4ft level will get you to within 1/4", if you are careful how centered the bubble is. Or you can go with Ben's idea of the water level http://www.deckmagazine.com/tools-an...ter-level.aspx.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
  1. need help leveling
    By tleigh0212 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 08:09 PM
  2. Leveling land with a roto tiller for a 14 ft pool.
    By ahutchins9 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-09-2011, 02:08 PM
  3. leveling for AGP
    By link6 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2011, 12:04 PM
  4. leveling
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 03-30-2007, 02:18 PM
  5. Questions about leveling
    By Trimom in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2006, 01:39 PM
