Results 1 to 10 of 10
Thread: Tiny micro bubbles coming from returns
    Apr 2012
    St. Louis metro area
    Default Tiny micro bubbles coming from returns
    Since we started using our pool this season, I have noticed tiny little bubbles coming from the returns. I'm not sure if we have an air leak somewhere in a suction line or if this might be caused by the swcg. I've also noticed that the basket on the pump is not full and the pump wants to re-prime itself sometimes. This makes me think that there's air coming in somewhere. Any ideas? I am going to test the water tomorrow, so I don't have any figures on levels right now.
    Edit: I have a 4 speed pump, which is normally running on the #2 setting. When it's running #3, the bubbles don't seem to be there and the basket on the pump is full.
    11,700 gallon Leisure Elegance 27 fiberglass pool, Pentair Intelliflo pump, IntelliChlor IC20 ECG, UltraTemp heat pump, IntelliBrite 5g LED light, EasyTouch 4, DeckJet II, Automatic Pool Covers AutoGuard Top Track
    Scottsdale, Arizona
    Default Re: Tiny micro bubbles coming from returns
    Clean and grease the o-ring on the pump basket.
    Apr 2012
    Thanks for the help. I'll try that.
    Apr 2012
    So, after further investigation, it looks like the swcg is causing the bubbles. I think the salt content is a little high, but could that be the problem? Or is the output set too high?
    mas985's Avatar
    Pleasanton, CA
    SWCGs normally create bubbles. These are hydrogen bubbles that are part of the electrolysis process.
    Mark
    Apr 2012
    Thanks for the help!
    Apr 2012
    Default Re: Bubbles coming from returns/pump basket not full
    So I cleaned and lubed the o-ring on the pump basket, but I am still getting air coming from somewhere. The pump basket does not stay full of water after priming. If I set the pump to the #1 setting (4 speed Pentair pump), it stopped drawing water completely and I shut it off before it went into alarm mode. Any ideas on what to check next?
    mas985's Avatar
    Pleasanton, CA
    So what are the four speed settings in terms of RPM?
    Also, what size is your plumbing and how many suction pipes go all the way from the pool to the pump?
    Can you post a picture of your equipment setup?
    Mark
    Apr 2012
    I found the air leak!! There was a bad o-ring on the suction line from the main drain. Thanks for the help.
  1. Vacuumed Debris is Coming Out the Returns
    By Shifty in forum Pool Equipment & Operations
    Last Post: 06-22-2012, 02:01 AM
  2. Bubbles from my returns?
    By gilbertpsk in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-17-2011, 05:31 PM
  3. Tiny Bubbles
    By rickw in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2006, 11:31 PM
  4. Re: tiny bubbles
    By rcastorani in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-21-2006, 08:55 PM
  5. CYA coming back through returns?
    By HooStat in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-25-2006, 09:57 PM
