Results 1 to 10 of 10
Thread: Tiny micro bubbles coming from returns
    Apr 2012
    St. Louis metro area
    Default Re: Tiny micro bubbles coming from returns
    Thanks for the help!
    11,700 gallon Leisure Elegance 27 fiberglass pool, Pentair Intelliflo pump, IntelliChlor IC20 ECG, UltraTemp heat pump, IntelliBrite 5g LED light, EasyTouch 4, DeckJet II, Automatic Pool Covers AutoGuard Top Track
    Apr 2012
    Default Re: Bubbles coming from returns/pump basket not full
    So I cleaned and lubed the o-ring on the pump basket, but I am still getting air coming from somewhere. The pump basket does not stay full of water after priming. If I set the pump to the #1 setting (4 speed Pentair pump), it stopped drawing water completely and I shut it off before it went into alarm mode. Any ideas on what to check next?
    mas985's Avatar
    Pleasanton, CA
    So what are the four speed settings in terms of RPM?
    Also, what size is your plumbing and how many suction pipes go all the way from the pool to the pump?
    Can you post a picture of your equipment setup?
    Mark
    Apr 2012
    I found the air leak!! There was a bad o-ring on the suction line from the main drain. Thanks for the help.
