Results 1 to 10 of 10
Thread: Tiny micro bubbles coming from returns
    mas985's Avatar
    Pleasanton, CA
    Default Re: Bubbles coming from returns/pump basket not full
    So what are the four speed settings in terms of RPM?
    Also, what size is your plumbing and how many suction pipes go all the way from the pool to the pump?
    Can you post a picture of your equipment setup?
    Mark
    Apr 2012
    St. Louis metro area
    I found the air leak!! There was a bad o-ring on the suction line from the main drain. Thanks for the help.
    11,700 gallon Leisure Elegance 27 fiberglass pool, Pentair Intelliflo pump, IntelliChlor IC20 ECG, UltraTemp heat pump, IntelliBrite 5g LED light, EasyTouch 4, DeckJet II, Automatic Pool Covers AutoGuard Top Track
