The PoolForum Search The PoolForum
  • Help
  • Forum
    • FAQ
    • Calendar
    • Forum Actions
      • Mark Forums Read
    • Quick Links
      • View Forum Leaders
  • What's New?
  • Advanced Search
  • Home
  • Forum
  • Pool Construction, Equipment, Operations, Seasonal Care (P)
  • Pool Electronics
  • Pool heater connection issue
  1. If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Results 1 to 9 of 9
Thread: Pool heater connection issue
  • Thread Tools
    • Show Printable Version
    • Email this Page…
    • Subscribe to this Thread…
  • Display
    • Switch to Linear Mode
    • Switch to Threaded Mode
  1. 06-06-2013 09:17 PM #1
    PoolDoc
    • View Profile
    • View Forum Posts
    Default Re: Pool heater connection issue
    PoolDoc / Ben
    Get the testkits you needBest Guess Chlorine Chart* PoolForum Amazon store *Edit your signatureSubscribe to the Forum
    BBB Method of Pool CareFixing Cloudy Pool WaterUsing muriatic acid to lower your pH SS Recipe PoolSolutions Guides
    Search PoolForum, PoolSolutions, and other pool websites.
    Reply With Quote Reply With Quote
Quick Navigation Pool Electronics Top
  • Site Areas
  • Settings
  • Private Messages
  • Subscriptions
  • Who's Online
  • Search Forums
  • Forums Home
  • Forums
  • Ben's Corner
    1. Notes and News from the PoolDoc
    2. Forum Q & A
    3. -- Subscriber Posts --
  • Pool Water: Treatment, Testing & Problems (P)
    1. Pool Chemistry for Intex-type Pools
    2. Testing and Adjusting Pool Water Chemistry
    3. Using Chlorine and Chlorinating Chemicals
    4. Salt Generators (SWCG) & other Chlorine Feeders
    5. Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    6. Dealing with Alkalinity and Calcium
    7. Dealing with Algae & Slime
    8. Pool Chemicals & Pool Water Problems
    9. DPD-FAS based testing
    10. Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    1. Intex-type Pool Setup & Operations
    2. In-Ground Pool Construction and Repair
    3. Above-Ground Pool Construction & Repair
    4. Pool Equipment & Operations
    5. Pool Startup, Shutdown, & Winter Operation
    6. Pool Cleaning: Manual or Automatic
    7. Pool Electronics
    8. Pools, Pets and Creepy Critters
  • Odds-n-Ends (P)
    1. Photo Gallery
    2. Clearance
      1. --cleanup--
    3. The China Shop
    4. General Interest
    5. Practice Forum
    6. PoolSolution Archive
    7. The Hall of Shame
« Previous Thread | Next Thread »
  • BB code is On
  • Smilies are On
  • [IMG] code is On
  • HTML code is Off
  • PoolSolutions.com / PoolForum.com
  • Archive
  • Terms of Service
  • Top
Powered by vBulletin™ Version 4.1.2
Copyright © 2026 vBulletin Solutions, Inc. All rights reserved.
(C) Ben Powell 2004 - 2014 - All rights reserved
