Re: B.B.B with the N2
Don't know about how borax will affect a nature2 but chlorine is chlorine and you need beteeen .5 and 1.5 FC with a nature2 system and liquid chlorine is fine for that use (bleach IS liquid chlorine) and baking soda IS sodium bicarbonate is sodium hydrogen carbonate which is what is used to adjust TA so these two are fine to use. If such products as Proteam Supreme and Bioguard Optimizer can be used with a nature2 system (I really don't know) then borax should be fine since it is basically the same thing.
BTW, your link is not correct
