Thread: Understood about calcium and vinyl, but fiberglass????
    May 2013
    Concord,ca
    Default Understood about calcium and vinyl, but fiberglass????
    I understand calcium hardness test is not necssary for vinyl, but does fiberglass need testing?
    Default Re: Understood about calcium and vinyl, but fiberglass????
    It depends on whether the fiberglass uses a calcium carbonate gelcoat. You could use some CH for safety -- say 150 ppm.
    May 2013
    Concord,ca
    That's xactly what I will do. Thanks to u C. Geek
    I did what you said didn't realize that stuff gets hot!!!
