Results 1 to 8 of 8
Thread: Questions
    BigDave's Avatar
    Default Re: Questions
    I see you're familiar with Ben's Best Guess Chart - great! It sounds like everything's under control and going well - Did I miss something?
    I wouldn't use the algecide (and then only polyquat 60%) unless you expect chlorine to drop (like during stain renoval).
    The bird donations are pretty gross, that's for sure. Perhaps keep the FC a little higher than the minimum, scoop out and vaccuum what you can see and the chlorine will destroy the microbes.
    gfritz1 is offline Registered+ Thread Analyst gfritz1 0
    May 2010
    Pennsylvania
    Just trying to make sure doing everything correctly
    Pump runs 12 hrs per day
    DE Hayward Pool inground vinyl 23000
    Check all readings weekly unless heavy use or grandchildren home
    Check chlorine daily and adjust to back above 5
    Water 82-84 Full sun
    Vacuum at least three times a week
    Other than that do nothing else - so my questions trying to get answered
    IS THIS ALL I NEED TO DO ?
    You said don't add algaecide unless you have algae issue or if driving FC low for stain removal - So think I understand that now
    Do I ever shock ? If so when and how ?
    Yes the birds are nasty and am sure others have experienced this . Any solution?
    16x32 rectangle 23K gal IG pool; trichlor feeder; Hayward HE-65 DE filter; Hayward 1.5 pump; 12hrs; Taylor Kit - can test FC-CC-CYA-ALK-Hardness; utility water;; PF:5.2
    Been on bleach since 2012
    You seem to have a good handle on things. I would test the pH more often than once per week however unless over a period of time you find that yours stays pretty steady. As far as shocking the pool, you actually don't ever have to routinely shock a pool as long as you keep your chlorine in the appropriate range based on your CYA level and have a CC reading less than 0.5ppm. When it is necessary, you can simply add a large dose of bleach to take the bleach up to shock level. You say that you add enough chlorine to get back to 5. This means that it is getting below 5 which is putting your pool at risk of an algae bloom. With a CYA of 90, you don't ever want to let the chlorine go below 5pp. Speaking of CYA, yours is already kinda high at 90. If it were my pool, I would quit using the trichlor pucks and just stick with bleach.
    May 2010
    Pennsylvania
    It was above 100 last year when did a partial drain and then a super shock for 24hrs at above 20 .This was when I had a zero chlorine reading and had followed the pool store adding stuff. Since doing that last year and getting a reading and being able to hold that reading day in day out including winter I have been 100% on bleach . I learned the hard way that all the stabilized tabs do is eventually get you into a problem . Using only bleach I assume over time my CYA will drop as water is lost though daily sun exposure and people splashing and refilled with rain water .I know it will take time. So you saying if I look at best guess chart I should be 5-10 which means then need to raise to 7.5 and hopefully then can catch each day so does not dip below 5. What is normal in chorine lost per day realizing a lot of things impact that ? Im seeing maybe 2-3 ppm adding the bleach in the morning. MY CC is basically zero
    Thanks again for all the help and answers
    You want to raise the chlorine high enough so that when you test in the evening, it is not below 5. Try going to 7.5 and if you still drop lower than 5, try 8, etc. Actually, with a CYA at 90, you might add enough bleach to take the chlorine to 10ppm and then you might not need to dose it for a couple of days. That is one advantage of having a higher CYA pool ---- less frequent additions of bleach. You just have to learn how your pool behaves. By the way, it is best to add bleach in the evenings when the sun is off the pool rather than in the mornings.
