Thread: Will I have to shock daily to get rid of algae?
    May 2013
    South Carolina
    Unhappy Will I have to shock daily to get rid of algae?
    My pool was left uncovered all winter and looked like a swamp, frogs and all. I've vacuumed, scooped and even used a leaf eater. So now my ph is 7.6 and I've add bleach about 5- 6 jugs two times this past week. The water is a lighter green than before I started, but not getting better. I thought I had gotten all the leaves and pinestraw out but I seem to be pushing around a couple of piles. Do I keep adding bleach everyday until I can see the floor of our pool? It's had to see if there is any debris left. :-)
    18 x 38 above ground pool. Hayward Power-flo LX pump, sand filter
    Jul 2012
    Mexico, Missouri
    Default Re: Will I have to shock daily to get rid of algae?
    Yes, you will have to MAINTAIN a "shock level" of chlorine in your pool for as long as it takes to clear your pool.
    Please read this thread for how you can get started with this process.
    Current pool balance numbers are important. If you don't have a Taylor K-2006, please order one. While you await it's arrival, go to your local Wal-mart and pick up the HTH 6-way test kit. Once you have a kit in hand, post your numbers here.
    Here is a guide for how high you will need to maintain your chlorine levels while you clear your pool of algae.
    You will also need to be running your pump 24/7 to help clear the pool, along with daily brushing.
    If I have forgotten anything here, I'm sure others will pop in to help.
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Apr 2012
    Texas
    I had to do this last year & everything charlie said is true. Ben & the other folks here helped me tremendously. Go ahead and stock up on a ton of bleach, because you go through more than you think. I think Walmart has been selling "ultra concentrated" bleach that is 8% and that might be easier to handle the smaller bottles since you're going to need so much. I don't know what kind of pump/filter you have? But you will have to clean or backwash filter frequently during this process.
    If you want to leave your pool open over the winter, you must spend a few minutes a week on maintanance, and it's easy breezy to get it swimmable in the spring I left mine open this past winter, just added bleach weekly, kept ph in check and spent a few minutes dipping out trash with a long net, let pump run on timer for a few hrs a day and this kept pool crystal clear all & sanitary all winter. Good luck you'll start making some headway soon as long as your pump/filter are working properly.
    18' round 7.5K gal AG vinyl pool; bleach; Hayward C900 cartridge filter; Hayward Power Flo Matrix 3/4HP pump; hrs; HTH 6-way test kit
    ; community; PF:16
