Results 1 to 9 of 9
Thread: new member from ohio
    Jun 2013
    Cincinnati, OH
    Default new member from ohio
    Thanks for all the great info. Found your site just this evening after wondering why my chlorine was getting 'eaten' up so fast. Forgot I added new water as I needed to change my vinyl liner. Ordering my Taylor test kit tomorrow. For now using the sticks and they are showing low 'stabilizer'. How much cya to add for a 17,000 gallon inground pool with sand filter? Ph and tot alk high normal.
    Default Re: new member from ohio
    We can't really advise how much CYA to add without knowing what your current reading is. Get the kit ordered and then post your results. In the meantime, pick up a cheap OTo kit (yellow and red drops). Post your pH and chlorine readings. Also, tell us exactly what all you have added to the water -- meaning ingredients and not just product names. What size pump and filter do you have?
    Welcome to the Pool Forum!
    Jun 2013
    Cincinnati, OH
    Got a HTH 6 way test kit from walmart. pH 8.2, total chlorine 0 (no free chlorine on the test strips), total alk 110. Added 1/2 gallon of liquid chlorine (10% sodium hypochlorite) and 6 ounces of 95% sodium bisulfate. Rechecked in 1 hour. ph 7.8, total chlorine >5 (free chlorine 4 on the test strips, total alk 100. Pool opened on 5/21. Liquid chlorine added on pool opening. Additional liquid chlorine added 5/25 along with 10 pounds of alkalinity rise (sodium hydrogen carbonate). No other chemicals used thusfar.
    Now needing to add CYA.
    16x32 rectangle with variable depth from 3 feet to 9 feet. Estimated 20,000 gallons.
    Jacuzzi Magnum force 1 HP pump, Hayworth sand filter.
    BigDave's Avatar
    The HTH 6-way has a CYA test - We'll need to know the CYA level to help.
    Jun 2013
    Cincinnati, OH
    Less than 30 on the test. More likely zero.
    BigDave's Avatar
    In 20000 gallons, 5lbs of granular CYA will all about 30ppm. It takes CYA a long time to dissolve, you can pour it slowly into the skimmer and wait for a few days or you can put it in an old sock and hang that in front of a return jet - squeeze the sock now and again to help it along. Be sure the CYA is pure Cyanuric Acid - 99.x% with no other active ingredients.
    Sometimes the label says isocyanuric acid instead of cyanuric acid. That is fine. Also, if you pour it into the skimmer like Dave mentioned above, leave your pump running 24/7 for 3 or 4 days afterward.
    BigDave's Avatar
    Good points Watermom, thanks.
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Hi cincyrick,
    If you plan to use a stabilized chlorine product, like the 3 inch tablets, you might want to consider adding very little or no stabilizer at all. This type of product has plenty of stabilizer and will add plenty of cya in no time. If you are going to use bleach, then disregard my comment.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
  1. New Member from Ohio
    By ely.cop.rock in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-20-2012, 04:31 PM
  2. Hi from Ohio
    By lporter1 in forum General Interest
    Last Post: 03-21-2012, 09:19 PM
  3. OH (Ohio) Water Hardness/ph -- Adding chems while filling?
    By rydeacowboi in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2007, 07:17 PM
  4. Never too early for Winter in Ohio
    By billk in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-23-2006, 03:13 PM
