Results 1 to 10 of 20
Thread: So lost!
    ratgirl is offline ** No working email address ** ratgirl 0
    Default Re: So lost!
    Hello, we've purchased a water testing kit that actually gives number results but the chlorine is too high to test the PH at the moment. Anyway, our water does seem a bit better, however the "waste" thing on the pump is leaking. Does anyone know why that might be happening? My step father just cleaned the pump free of TONS of leaves that we had no idea were there, and since then the waste things been leaking. I dunno what would cause that, and he's getting angry over the whole thing. *sigh* We should have just gotten someone to come in and open the pool for us, and show us the workings of the thing.
    OMGosh, I can see the skimmer all the way down to the bottom of the pool! This must be good. Will continue bleaching for a few days.
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Just want to throw in that you can often go to the manufacturer of the pump/filter's website and get the documentation you need to see that the thing's set up and running right. Get the name of the pump and plug it into Google (your next best friend after this forum!).
    ChuckD
    <3 Thank you!
    Gah, I just wrote, and posted an edit, but it doesn't appear to have posted.
    Anyway, I looked at the filter and it's a Hayward swim pro high rate sand filter. There was a model number on it(SW166T) but I couldn't find it on their website at all!
    I have some pictures of it, so perhaps someone might recognize it, and be able to tell me if it's connected properly?
    http://img.photobucket.com/albums/v4...a/100_3106.jpg
    http://img.photobucket.com/albums/v4...a/100_3105.jpg
    http://img.photobucket.com/albums/v4...a/100_3104.jpg
    Thank you.
    Duanesburg, NY
    Quote Originally Posted by ratgirl
    Thank you.
    I'm thinking you may have misread that number and it's actually one of these:
    http://www.haywardnet.com/products/d...ductID=41#five
    The smaller certainly looks like it.
    ChuckD
    Okay, so I guess according to that manual our filter is hooked up properly. So that's a good thing. Anyway I used one of those test strip thingys and the free chlorine is way over 10 because it immediately turned darker purple than the one that represents 10. Our PH is over 8.4, total alkilinity is between 120, and 180 which the thing says is between ok and high, and the cyanuric acid was between 100 and 150 which is between ok and high. Our pump has been running all day for the last 2 days, we've been puting loads of chlorine in, and still the water is bad. We're getting ready to just give up and sell the thing. *sigh* Any more suggestions?
