Results 1 to 10 of 20
Thread: So lost!
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Default Re: So lost!
    Just want to throw in that you can often go to the manufacturer of the pump/filter's website and get the documentation you need to see that the thing's set up and running right. Get the name of the pump and plug it into Google (your next best friend after this forum!).
    ChuckD
    ratgirl is offline ** No working email address ** ratgirl 0
    <3 Thank you!
    Gah, I just wrote, and posted an edit, but it doesn't appear to have posted.
    Anyway, I looked at the filter and it's a Hayward swim pro high rate sand filter. There was a model number on it(SW166T) but I couldn't find it on their website at all!
    I have some pictures of it, so perhaps someone might recognize it, and be able to tell me if it's connected properly?
    http://img.photobucket.com/albums/v4...a/100_3106.jpg
    http://img.photobucket.com/albums/v4...a/100_3105.jpg
    http://img.photobucket.com/albums/v4...a/100_3104.jpg
    Thank you.
    Duanesburg, NY
    Quote Originally Posted by ratgirl
    Thank you.
    I'm thinking you may have misread that number and it's actually one of these:
    http://www.haywardnet.com/products/d...ductID=41#five
    The smaller certainly looks like it.
    ChuckD
    Okay, so I guess according to that manual our filter is hooked up properly. So that's a good thing. Anyway I used one of those test strip thingys and the free chlorine is way over 10 because it immediately turned darker purple than the one that represents 10. Our PH is over 8.4, total alkilinity is between 120, and 180 which the thing says is between ok and high, and the cyanuric acid was between 100 and 150 which is between ok and high. Our pump has been running all day for the last 2 days, we've been puting loads of chlorine in, and still the water is bad. We're getting ready to just give up and sell the thing. *sigh* Any more suggestions?
    Downingtown, PA
    ***This advice is based on test strip results which are border-line useless. Get results from a pool store or use a kit and dilute the water if necessary.***
    Ratgirl,
    There have been discussions on this post about the effectiveness (or lack there of!) of chlorine at high pH levels. I am not sure how much an effect a 8.4pH would have but it is NOT GOOD! You need to add some muratic acid as chlorine is most effective in the 7.2-7.4 zone of the safe range. Once you have the pH down some I think the chlorine will be more effective in cleaning up the pool.
    I noticed that the CYA is between 100-150 (need more specific numbers) but this coupled with the high pH is rendering that 10ppm of chlorine rather useless. You need to get the chlorine level into shock territory for CYA of >100 and also get the pH down ASAP!
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    IL.
    I was just reading some info today that stated chlorine was most effective at PH levels too acidic for a pool. At the recommended PH of 7.6, it is only 50% effective. Any higher and the effectiveness drops off the map.
