Thread: Calcium Hardness in Pebble tec pool
    Aug 2012
    Gilbert, AZ
    Default Calcium Hardness in Pebble tec pool
    I've never had this come up before but last time I had my water tested at Leslie's they warned me about my low CH levels. I did just refill the pool this season with city water.
    Just tested the pool and here are my results.
    FC-3.6 (already added another lb of dichlor)
    PH-7.6
    CH-250
    I'm not very certain I'm doing the CH test correctly though, K2006 kit says red should turn blue with the drops but It's hard to differentiate from when it turns purple then blue.
    Anyways, where should it be? I would have to order Leslie's "Hardness Plus" as they don't carry it in the store.
    Thanks!
    Jul 2012
    Mexico, Missouri
    Default Re: Calcium Hardness in Pebble tec pool
    Check the poolsolutions.com guide:
    http://poolsolutions.com/gd/poolsolu...guide.html#cal
    15' round 4.8K gal Intex AG pool; Intex 633 pump with twin canisters (2500 gph main filtering); Unicel 5315 filter cartridges; Intex 637 pump w/o filter (1000 gph heater circulation); 4hrs; K-2006; utility water; PF:24
    Recommended levels of Calcium Hardness for a hard-sided pool is 200-400ppm. Sounds like you are fine.
    Recommend levels od calcium for a vinyl pool is 0....not needed.
