How to replace return jet fitting
Hi, we found a leak in our inground pool. It was leaking around a return jet fitting, we removed the fitting and are attempting to replace it. We can't get the new fitting through the small hole in the liner. Is there a trick to doing this? Will we have to disconnect the liner and slide it in between the liner and the pool wall?
