Thread: They say not structural
    Jul 2012
    Default They say not structural
    Poolco says my crack is only a hairline crack and not structural. Says it's normal.... They still haven't come out and are saying this based on my picture. Structural warranty and a plaster warranty exist.
    What should I accept at a minimum to fix this?
    http://www.poolforum.com/pf2/showthr...on-gunite-pool
    I had no responses until I called the boss direct.
    So frustrating. I had a pool prior and my only issue was cloudy water and needing a new liner after 15 years....
    I would never buy a gunite pool again.
    Marin is offline In the pool biz Thread Analyst Marin 2 stars Marin 2 stars
    Jun 2013
    Oklahoma
    Default Re: They say not structural
    Caveat - I can't see a picutre.
    Hairline cracks in pools are generally just an eyesore and not a problem. Typically not until you can stick a toothpick in the crack is it concern for a leak. Even then most don't lose water.
    How old is the pool?
    Where is the crack?
    @wishIcould: you can post pictures using Flickr, Webshots, Picasa, Google Docs, Dropbox, etc. Just find the link for your picture, and post between two IMG tags -- clicking the little picture symbol on the edit tool bar will enter those tags for you.
