Thread: 10% sodium hyperchlorite
    May 2013
    Concord,ca
    Default 10% sodium hyperchlorite
    Is 10% sodium hyperchlorite ok or does it need to be 12
    Default Re: 10% sodium hyperchlorite
    10% is fine. Even 8.25% or 6% bleach is fine if it is unscented and not "outdoor" or otherwise unusual in having thickeners in it. The only differences will be in the concentration. Sometimes bleach is more economical; other times chlorinating liquid is cheaper (per FC). Of course, the more concentrated product is less heavy to carry for the same amount of FC.
    Sep 2012
    Kentucky
    I am actually using 5.25% bleach and have had great success with it. So 10% should be fine.
    JnKY
    30' Round 24K* gal AG Vinyl Pool; 5.25% Bleach; Hayward IS210T Sand Filter; Hayward SP1580 1 speed pump; Utility Water; Taylor K-2006C Test Kit
    It doesn't matter. All that matters is that ultimately you get enough chlorine in the water.
  1. Percentage sodium hypochlorite?
    By Mindiv in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-06-2013, 04:31 PM
  2. sodium hydroxide?
    By Charlie_R in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-19-2012, 04:39 PM
  3. sodium persulfate
    By topless in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2007, 09:38 AM
  4. Is sodium bicarbonate same as sodium carbonate?
    By mshumack in forum Dealing with Alkalinity and Calcium
    Last Post: 09-18-2006, 08:52 PM
  5. Sodium Tetraborate
    By bassadict69 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-21-2006, 12:38 AM
