Thread: New pump Hayward Max II 3/4HP and Sand Dollar 150 lbs filter air leak
    Default New pump Hayward Max II 3/4HP and Sand Dollar 150 lbs filter air leak
    The pump will not prime it will bring in water but the pump pot will not glass over.
    I've checked for leaks by setting the filter to close and fixed one leak but still have
    air. the pool is 10,000 gallon 25 foot round and the pump is about 27 feet from
    the skimmer. the pump is about 2.5 to 3 feet above the water line. I have about
    a 10 inch run from pump intake to 90 degree drop into the ground
    Default Re: New pump Hayward Max II 3/4HP and Sand Dollar 150 lbs filter air leak
    Gonna trying running new PVC straight to the pool just to see if I can
    get suction enough to at least circulate the water and eliminate
    the air leak from the old roll pipe they used back then.
    Then this will tell me if the pump just sucks
    Put a ball valve in and had it set at 20 lbs of pressure and got it to at least
    almost fill the filter bowl and not air out but barely any flow out the return.
    No way I can vacuum. Doesn't suck enough to run to waste.
    I'm waiting for glue to setup bypassing the original suction side (Possible air leak)
    and running a line straight from the pump to the pool
    I think the pump is about 4 foot from the water line
    Don't think this pump can cut it. So word to the wise if you think you can
    get away with a 3/4 HP pump and are over 25 ft with another 4 foot in lift
    better double it and get the super pump
    Funny thing is I had a 3/4 Jacuzzi pump before and worked like a champ
    till the salt ate it up
    4 foot lift and 22.5 ft of straight pipe
    Went back out there after 20 minutes
    Pump was primed and running at full pot
    so I must have a bad leak on my original suction side
    COuld a 1-1/2 HP super pump overcome a leak?
    You clearly have a leak somewhere you need to find and fix.
    just hoping its not under the pool deck or behind the skimmer
  1. How To Repair Leak in Sand Filter
    By wapate in forum Pool Equipment & Operations
    Last Post: 06-18-2012, 11:13 PM
  2. Hayward Super pump leak
    By RRich in forum Pool Equipment & Operations
    Last Post: 01-27-2012, 10:11 AM
  3. Hayward Super Pump Leak
    By CapitalBoo in forum In-Ground Pool Construction and Repair
    Last Post: 05-10-2011, 04:50 PM
  4. Hayward Pump and Sand Filter Issue
    By kevev99 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-12-2010, 07:14 PM
  5. Hayward Pump Leak
    By tommy_b in forum Pool Equipment & Operations
    Last Post: 06-07-2006, 04:58 PM
