I don believe there is. Cant see the bottom. I gave it a good sweep. Will check chlorine levels here shortly. Been raining non stop all day so i am sure its deluted some.
18x36 3.5 - 8' depth, IG pool with SWCG; ~21K gal
Should I get my CL up around 26-30 so it doesnt drop below 20 during the day when I am at work? I start the day at 20 or a little higher and its down to 16ish at night. Dont seem to be making much headway with the green.
Right! enough chlorine to keep the FC at or above shock level at all times.
