need help and advice on pool opening
Big hello to you all!
Before I begin, just wanted to let you know how great it was using my pool last summer after converting from Baqucil to bleach! Lots less work and sparkleing clear water! Amazing-I converted my neice and am still working on my cousin.
Ok, here are my readings with the HTH test kit: Chlorine-not even registering on the tester; PH-8.2; Alkalinity:50ppm; hardness-50ppm; CYA-40ppm. Volume of the pool is 8496 gal and we are just uncovering and topping the water level now.
Aside from pouring in a couple gallons of bleach, what else do you reccomend?
