Thread: Cloudy Water
    bacrocker is offline ** No working email address ** bacrocker 0
    Default Cloudy Water
    Help, our water is still really cloudy. Any suggestions?
    CYA-120
    Tot chlo-3.4
    Free Chlor-3.4
    ph-7.7
    tot alk-176
    adj total alk-140
    tot hardness-97
    Copper-0
    Iron-0.2
    no algae
    Thanks, Beth
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Cloudy Water
    Your CYA level is very high. Check out this thread
    http://www.poolforum.com/pf2/showthread.php?t=365
    Your chlorine levels are not high enough for your CYA levels. If the chlorine is not high enough the water can turn cloudy.
    Is your pool plaster, vinyl, or fiberglass and how many gallons.
    It is a 25,000 gal IG vinyl.
    We have been adding extra bleach to it, but apparently not enough.
    Canada.
    Mine is also cloudy. Just came in from shocking for the 2nd time. I hope that tomorrow it will look better! Here's what it looked like 24 hours ago, and now tonight after second shocking
    Attachment 227
    Attachment 228
    Swansboro, NC, USA.
    Cool Re: Cloudy Water
    That is exactly what mine looked like and is looking like right now!! Its a pretty color but cloudy! Let me know what you are doing to get it clear again!
    Thanks!
    On the right track--keep going! Lots of chlorine--keep it at shock levels, filter 24/7, brush EVERYDAY and vacuum to waste. You are almost there--couple of days!
    Well Done!
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
