Thread: Replacing the rotating swich on AO Smith Motor
    May 2013
    Northeastern US
    Default Replacing the rotating swich on AO Smith Motor
    Any of you guys do this? Is there a way to remove the screw that mounts the switch to the shaft WITHOUT bending back the ears that hold the contact? That is a hard screw to get to. Thanks.
    Default Re: Replacing the rotating swich on AO Smith Motor
    First you remove the spring, then you pop out the piece that moves. You shouldn't have to bend the ears to do it, it should have enough give to pop out. Then you put a wrench on the flats of the shaft to hold it while you remove the screw.
    May 2013
    Northeastern US
    Thanks, but I never realized that once those springs came off, you could just pull it out. Looks pretty tight in there to me..
  1. Replacing/Upgrading my Pump. A.O Smith
    By djspawn00 in forum Pool Equipment & Operations
    Last Post: 06-14-2012, 01:12 PM
  2. Wiring a 2 speed A.O. Smith pump motor
    By wack70 in forum Pool Equipment & Operations
    Last Post: 08-26-2011, 12:47 PM
  3. Bearing Replacement 1hp AO Smith Motor
    By Spurgeon in forum Pool Equipment & Operations
    Last Post: 05-15-2010, 02:18 AM
  4. AO Smith replacement motor suddenly noisy
    By rbonin in forum Pool Equipment & Operations
    Last Post: 05-31-2009, 01:00 PM
  5. Sta-Rite Pump / A. O. Smith motor stopped
    By Longgrove in forum Pool Equipment & Operations
    Last Post: 06-11-2008, 02:34 AM
