Results 1 to 9 of 9
Thread: Easy set 10' x 30"
    Default Re: Easy set 10' x 30"
    membership upgraded.
    Intex startup recipe: http://www.poolforum.com/pf2/showthread.php?17055
    One reminder - with the Easy Set (inflatable do-nut) pools, there are two things that many folks don't get right:
    1. Level ground means really, really level. The Easy Set is really not tolerant of even slight out-of-level conditions.
    2. Over-inflating the donut will reduce ring life -- when the ring gets hot, pressure increases. If you already started with max pressue, bad things will happen.
    BigDave's Avatar
    My experience echoes Ben's warning. I had to drain my first donut pool when I first tried to fill it. It was less than 3" off level. The pool moved toward the low side and stretched. Level means measured level not looks level. Even a difference of an inch will be exaggerated as the pool moves to the low side.
    Jun 2013
    Near sunny Buffalo NY
    Level and do not over inflate the ring. Noted. Thanks.
  1. New Intex Easy Set 15' x 48" owner - first time pool guy
    By burmjohn in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-02-2012, 12:17 PM
  2. replacment ladder for 48" intex easy set abp
    By 4nick8er in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2011, 10:23 AM
  3. Advice for Easy Set 12' x 36" pool
    By golfwig in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-20-2006, 02:29 PM
  4. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
