Re: Yikes! Filled pool, and now just discovered 'Index Dose' Method!
Ok, just tested water...
Cl: 1
pH: 7.5 - 7.8 (closer to high end)
CYA: <30 (duh)
Alk: 150
Hard: 230
(Using HTH 6 Way)
Add two more doses (one cup) to bump the Cl a little? How do I get the pH to drop?
I'm all for keeping it simple over the summer by only using bleach and borax; any harm in not using the dichlor tabs?
Gah! Just realized the title of this thread is 'Index' instead of 'Intex'...fat fingers!
