Thread: Aquarite SWG not Generating Chlorine
    Default Re: Aquarite SWG not Generating Chlorine
    I agree with that statement, Goldline were very accomodating and didnt seem to flinch one bit when deciding to send a replacement unit even though I am less than 2 months away from the end of my warranty. I was expecting a bit of a fight, or stalling tactics so they could charge me for repairs, and at the very least I was expecting that they would want me to send my cell in for repairs and shut the pool down for a week or 2 while they make a decision but they just went through about 5 minutes of troubleshooting and verified my address and it was all done.
    Saint Cloud, FL
    When you get the new cell, I would recommend checking the volts and amps soon after it is installed and turned on, and include date and time, so you will have a reference point.
    Pat
    I called Goldline controls. They suggested that I acid clean the cell. I did that today and have run the filter for 4 hours since with no noticable difference. Will call them again tomorrow.
    Consider having your pool water tested for phosphates. I was having the same problem last year and discovered my phosphates were very high. It took some work to get rid of them, but whereas last year I was running at 80% with very little production, this year I am running at about 20%.
    Also, slightly loosen the union at the downstream side of the cell and collect the water while the cell is generating. Test that water and see what the Cl tests.
    Quote Originally Posted by buzzhazzard
    2 good points here. If phosphates are a limiting factor in algae growth in your pool you might always be fighting algae which can explain a high chlorine demand. However you would most likely be showing CC all the time.
    Checking the water right after the cell will certainly tell you if it is working or not. It should be very high (use OTO to test since it doesn't bleach out)
