Results 1 to 9 of 9
Thread: is bleach really cheaper?
    Jun 2013
    Delaware
    Default is bleach really cheaper?
    I read on one of the guides or tips that one gallon of 6% bleach is comparable to 3/4 lb. of Calcium Hypochlorite.
    I can get a 3.78 jug of 8.25% bleach at Walmart (Great Value brand) for $3. I can get a 50 lb. bucket of Calcium Hypochlorite at "in the Swim" through Amazon for $156. It is listed as 65% Available Chlorine (35% Calcium).
    If I need 67 gallons of 6% bleach to equal the 50lb. bucket I would need 52 of the 3.78 qt. jugs of 8.25% bleach and at $3 per jug that actually comes to $156. 52 jugs of bleach means hauling 416 pounds which is much less convenient than a 50 lb. bucket of granules.
    I'm not arguing with the logic of buying cheaper chemicals than at the average pool store and I believe the online price is much cheaper than my local pool store. I'm just asking to see if I am missing anything?
    Default Re: is bleach really cheaper?
    Bleach isn't always cheaper but it is the chlorine source that adds the least amount of extra stuff to your water. There is nothing wrong with using other types of chlorine. You just have to determine what your pool needs. Cal-hypo adds calcium which is needed in a gunite pool at a level of 200-400ppm. But, if it gets too high, then you can have cloudy water issues. Trichlor pucks add CYA which is fine if your stabilizer is low. They are also very acidic which is ok if your pH runs high. But, continued use of trichlor causes a lot of people to end up with a CYA level that is way too high. Most people do not understand that high CYA requires high chlorine and when they get algae, they don't understand why. Dichlor has the same things as trichlor -- very acidic and adds CYA. All that bleach (sodium hypochlorite) adds is salt. It is also readily available. So, those are a couple of reasons why it is a good choice for many pools.
    But, like you said, it is not always the cheapest nor the most convenient. Depends on individual situations.
    Welcome to the Pool Forum, by the way!
    Jun 2013
    Delaware
    Thanks for the reply (and the welcome!) Watermom. That makes sense. I wanted to make sure I wasn't missing something obvious in my calculations.
    I've had this pool for 10 years. I just discovered this site and have learned much about pool chemistry and feel I finally know why I have had all the issues (mostly algae blooms) I have experienced. I threw away my test strips and am using a Taylor 2006C test kit. I have a plaster 30,000 gallon pool.
    Quote Originally Posted by tfrailey View Post
    Good decision!
    membership upgraded.
    BigDave's Avatar
    I love this thread. OP has already figured out that chlorine is chlorine an is questioning assumptions.
    May 2013
    Concord,ca
    All I can say is I use the calculator and place 12% in the bleach spot as I use ch. No problem though, Yesterday my 2006 said add 3.5 cups of 12% and 1.2 cups muriatic acid. I did and today my pool is sparkling. I cannot use the bleach calculator but since I cannot trust cheap brands anyway I'll just stick with what I get from the pool store. BTW can a chlorine granular be used if it is put in water first? I have a fiberglass pool and don't want a floater.....Thanks again Dave
    May 2010
    Central NJ
    I have been using super cheap 6% bleach from Aldi for years. I have tested it and followed its effect on my pool by testing the pool. It is 6%. Exactly as advertised. No need to get more complicated or more expensive. I don't try to keep any over winter though.
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    Virginia
    Like you have discovered, bleach isn't always the cheapest solution. Last time I checked cal hypo was cheaper than bleach in my area.
    However, since I have a SWCG I only need another CL source when shocking I decided to stick with bleach since like was said earlier it only adds salt. I don't want to be adding calcium since in my vinyl pool the only thing it does is possibly foul the salt cell.
    So bleach is costing me a little more, but the benefit is worth it to me.
  1. A cheaper alternative to Grocery Store Baking Soda....
    By msumoose in forum Dealing with Alkalinity and Calcium
    Last Post: 04-20-2012, 01:41 PM
  2. Polaris foam tail scrubber -- cheaper source?; Silt bag tip
    By tsuma in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-02-2008, 01:31 PM
  3. Isn't 10% "liquid chlorine" cheaper than bleach?
    By kearpaul in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-14-2007, 03:03 PM
