Results 1 to 10 of 27
Thread: Sand in pool
    Jun 2013
    Central Florida
    Default Re: Sand in pool
    I mostly use a nylon brush for routine cleaning, but I have the SS brush for the occasional heavier need. The surface is at least 7 years old and a little rough in spots. The previous owner said refinishing after 10 - 12 years would not be unexpected. Don't know if that's right or not. If so, I'd expect to refinish in 3 - 5 years. I'd probably want to do it anyway to fix the "pockets" that in in floor pop-ups are in.
    Marin is offline In the pool biz Thread Analyst Marin 2 stars Marin 2 stars
    Jun 2013
    Oklahoma
    Really depends on care. Some folks need refinishing after 7 years, some go 20+ years.
    When you replaster, make sure your contractor uses the infloor collar extensions to raise the heads up level with the new plaster.
    Greg
    Marin Pool Restoration
    Jun 2013
    Central Florida
    Would it be unreasonable to expect a refinisher to grind down around the in floor fittings and main drain., etc. so the new finish is flat ?
    Jun 2013
    Oklahoma
    When we replaster a pool we set a new main drain cover and use the infloor collar extensions to keep things flush. Other items, like lights and return fittings, we chip out around those so we can bring the plaster back flush with the fitting.
    Greg
    Jun 2013
    Central Florida
    Thanks. I'll keep an open mind. I suppose if I want it done a certain way that is not standard practice, it becomes a cost/ benefit trade off.
    Jun 2013
    Oklahoma
    In the past we have chipped out around the infloor heads to bring the plaster flush, by we have to go back about 2' around each one to do it well. Not worth it when the collar extensions have no effect on the performance.
    Greg
