Results 1 to 10 of 27
Thread: Sand in pool
    Marin is offline In the pool biz Thread Analyst Marin 2 stars Marin 2 stars
    Jun 2013
    Oklahoma
    Default Re: Sand in pool
    When we replaster a pool we set a new main drain cover and use the infloor collar extensions to keep things flush. Other items, like lights and return fittings, we chip out around those so we can bring the plaster back flush with the fitting.
    Greg
    Marin Pool Restoration
    Jun 2013
    Central Florida
    Thanks. I'll keep an open mind. I suppose if I want it done a certain way that is not standard practice, it becomes a cost/ benefit trade off.
    Jun 2013
    Oklahoma
    In the past we have chipped out around the infloor heads to bring the plaster flush, by we have to go back about 2' around each one to do it well. Not worth it when the collar extensions have no effect on the performance.
    Greg
