Here's my numbers
The test kit is a 5 way from Walmart.
Water temp is 80 degrees
Chlorine is .5
PH is 6.8
Alk is 30
CYA was zero last Saturday
24' round 48" deep
14,400 gallons
I have been using 1" pucks because I don't have any CYA and trying to kill two birds with one stone (raising both CYA and chlorine). I have very little of the pucks left since opening the pool on Saturday.
Got rid of most of the debri by vacuum and backwash, skimmer has run 24/7 and can see the bottom of the pool. Tonight I added a whole box of borax to raise the PH and one 3" puck of cal-hypo to the floatie thing.
Am I on the right track?
Thank You
Nicole
- You may not post replies
- You may not edit your posts
Forum Rules
