Results 1 to 10 of 12
Thread: Changing to a smaller impeller
    michael3 is offline Registered+ Thread Analyst michael3 0
    May 2013
    Default Changing to a smaller impeller
    I have a Hayward powerflo LX 1.5 hp pump, the water flow is way to fast for my sand filter, I have looked the pump model up and they make impellers all the way down to a 1/2 hp. What would be a reasonable size to drop to? I was thinking maybe 3/4
    mas985's Avatar
    Pleasanton, CA
    Default Re: Changing to a smaller impeller
    How do you know the flow rate is too fast?
    Also, what size is your filter and what is the current filter pressure?
    Was the pump sold with the filter?
    But I believe with the Powerflo LX, you can only drop it to a 1 HP which would still be ok.
    Mark
    May 2013
    Mas985, I have a real long thread over at the balancing water forum. I bought the pump new off eBay and got sand filter on Craigslist. Sand filter is a Hayward s200. I run 17 psi on filter, recirculate. And 10 on backwash. Psi never goes up. Started with algae, killed it but best guess is pump pushed dead algae through filter to fast to filter it out. Got a cloudy mess now. Watermom and Ben has been giving great advise. In short though the return flow to the pool is very powerful so I'm looking to slow it with smaller impeller or a shut off valve between pump and filter and close it enough to slow the flow. I saw impellers for this pump down to 3/4 but maybe 1 hp would help
    mas985's Avatar
    Pleasanton, CA
    One thing to keep in mind is the typical sand filter will filter down to 30-40 microns or so and some dead algae is actually smaller than that so it can be pushed through the filter without much effort. Some people have used DE in their sand filters to help capture the smaller algae. Have you tried that?
    As for the pump, a quick calculation and my guess is that the flow rate is not much beyond the design rate of the filter (44 GPM). Maybe as high as 54 GPM but certainly not enough to cause any damage.
    A smaller impeller may help but as I mentioned before, there are some things a sand filter just can't remove without a little help.
    If you want to see if a smaller impeller would help, one idea would be to add enough head loss to slow the flow rate down to around 44 GPM. If you have a return valve, you can try closing that until the filter pressure reads above 22 PSI. That should result in a flow rate less than 44 GPM. If the algae still makes it through the filter, it is probably too small for the filter to capture but again, DE might help with that.
    Also, can you post a link to the 3/4 HP impeller? Just want to make sure it is for that model. Not all Powerflo's use the same impeller.
    Mark
    May 2013
    mas985, the part number I saw was spx1500F says it will fit on the sp1580. I ended up adding a valve between pump and filter, half way closed my pressure reads 8-10 psi, so my pressure drops instead of rises to 22. and my water flow slowed quite abit into the pool
    BigDave's Avatar
    That should give you an idea of how your filter will operate with a smaller pump (impeller). I can't guess how close, but the same direction - maybe mas985 can give you a better idea. If you do like it then definitely change the impeller to save on electricity.
