Results 1 to 10 of 12
Thread: Changing to a smaller impeller
    BigDave's Avatar
    Default Re: Changing to a smaller impeller
    That should give you an idea of how your filter will operate with a smaller pump (impeller). I can't guess how close, but the same direction - maybe mas985 can give you a better idea. If you do like it then definitely change the impeller to save on electricity.
    mas985's Avatar
    Pleasanton, CA
    The filter pressure I gave you is for when a throttling valve that is after the filter. So using a valve before the filter, you want the pressure to drop to around 11 PSI and then the flow rate should be lower than 44 GPM.
    The spx1500F would be a two steps down but it still may not be below 44 GPM although probably close.
    Mark
    michael3 is offline Registered+ Thread Analyst michael3 0
    May 2013
    ok, that makes sense. The one I installed yesterday is between pump and filter, and its running between 8-10 psi. I think I will hold off on the impeller change and see if this will help me. I hope to get some DE to add today and see if it will help. When adding the DE do I remove the skimmer basket and pump basket or just skimmer basket?
    BigDave's Avatar
    The DE should be fine enough to pass through the baskets.
    May 2013
    Ok, thanks. I couldn't resist checking the sand, and sure enough, the sand I blew out on initial backwash caused me to be low on sand and the sand that's in there isn't anything like the old I took out, the new was more like play sand. I wanted to remove my lateral assembly but on my s200 the variflow comes in on the side and I couldn't get the bulkhead fitting off. Best I could tell laterals look fine. So with proper sized filter sand and some DE I hope to get my pool clean
    mas985's Avatar
    Pleasanton, CA
    BTW, the DE will serve two purposes, it cleans the pool better but it also will add head loss to the filter and slow down the flow which should also help clean better.
    Mark
  1. Possible Impeller Problem
    By godstreasures1 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2008, 04:55 PM
  2. Taylor DPD scoop smaller, how much to use?
    By CTIGuy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-23-2007, 09:28 PM
  3. How to Remove Impeller off Motor
    By colby in forum Pool Equipment & Operations
    Last Post: 08-11-2007, 10:07 AM
  4. impeller cavitating
    By fuelman in forum Above-Ground Pool Construction & Repair
    Last Post: 09-21-2006, 06:58 PM
  5. Help with clogged impeller
    By pool newby in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 11:54 PM
