Results 1 to 10 of 12
Thread: Changing to a smaller impeller
    michael3 is offline Registered+ Thread Analyst michael3 0
    May 2013
    Default Re: Changing to a smaller impeller
    Ok, thanks. I couldn't resist checking the sand, and sure enough, the sand I blew out on initial backwash caused me to be low on sand and the sand that's in there isn't anything like the old I took out, the new was more like play sand. I wanted to remove my lateral assembly but on my s200 the variflow comes in on the side and I couldn't get the bulkhead fitting off. Best I could tell laterals look fine. So with proper sized filter sand and some DE I hope to get my pool clean
    mas985's Avatar
    Pleasanton, CA
    BTW, the DE will serve two purposes, it cleans the pool better but it also will add head loss to the filter and slow down the flow which should also help clean better.
    Mark
  1. Possible Impeller Problem
    By godstreasures1 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-09-2008, 04:55 PM
  2. Taylor DPD scoop smaller, how much to use?
    By CTIGuy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-23-2007, 09:28 PM
  3. How to Remove Impeller off Motor
    By colby in forum Pool Equipment & Operations
    Last Post: 08-11-2007, 10:07 AM
  4. impeller cavitating
    By fuelman in forum Above-Ground Pool Construction & Repair
    Last Post: 09-21-2006, 06:58 PM
  5. Help with clogged impeller
    By pool newby in forum Pool Equipment & Operations
    Last Post: 07-17-2006, 11:54 PM
