Thread: Backwash problems
    Jun 2013
    Buffalo, NY
    Default Backwash problems
    On a haywood filter system backwash and rinse has extremely low flow of water, yet filter and others are working fine. Have replaced lateral and "arms" in the filter and valve system - at the advice of pool store - although they suggested replacing the gasket I had replaced the spring a few times and was tired of it all. But obviously did not solve the problem - have taken filter apart 2 times, hoses are connected correctly - it makes no sense! Help.
    BigDave's Avatar
    Jul 2010
    New Jersey
    Default Re: Backwash problems
    How about the waste setting? Where does the backwash water go after it leaves the valve?
    12'x24' oval 7.7K gal AG vinyl pool; ; Hayward S270T sand filter; Hayward EcoStar SP3400VSP pump; hrs; K-2006; PF:16
    I think BigDave is on the right track: verify that the backwash discharge line is not restricted -- possibly by cutting it, and connecting the backwash port to a backwash hose.
    Jun 2013
    Buffalo, NY
    The waste setting does work
    BigDave's Avatar
    Jul 2010
    New Jersey
    Where does the backwash go?
    Jun 2013
    Buffalo, NY
    It comes out but at a very low rate - almost non-existent
    In that case, I'd recommend opening the valve, and see if there are any internal obstructions. If the "Filter" position works, the piping IN the filter, almost has to be OK, but there could be something wrong internal to the valve.
