Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 31
Thread: CYA levels
    Aug 2012
    Gilbert, AZ
    Default Re: CYA levels
    What should my goal TA be?
    Aug 2012
    Gilbert, AZ
    Well I got my pH down to 7.2 but TA is still at 140. But now the water is no longer crystal clear..back to cloudy. Is the pH too low? Seems like my sweet spot was 7.4-7.6 when it was crystal clear. I've been running the pump all afternoon with it aerating. We're having a party today and wanted the pool looking perfect but oh well.
    7.2 is fine. But, you don't want it lower.
    What is your chlorine level? Cloudiness may indicate an impending algae bloom. Since your CYA is really high, you'll have to run high chlorine levels or you are gonna continuously have algae problems. (If you haven't already done so, read the Best Guess Chlorine Chart in my signature below.)
    Aug 2012
    Gilbert, AZ
    I think you hit the nail right on the head. Water now has a green tint to it and getting worse. My CL level was a 8, so now im dosing with 8% bleach to raise it to 25 (per the best guess chart for the shock value).
  6. #16
    Aug 2012
    Gilbert, AZ
    Water is still greenish, tested and got a 22ppm for CL and pH is back to around 7.5 and TA 130. I need to make another bleach run, but I'm curious how long it will take to clear up with keeping the CL at 25 and running pump 24/7?
  7. #17
    There is no way to predict that. See if you are losing chlorine overnight. Test it this evening after the sun is off the pool and then again in the morning within one hour of sunrise. Report back and tell us how much chlorine you lose overnight.
    Two questions for you:
    1. What was the source of your fill water?
    2. Check the ingredients on the trichlor tabs you used. Does it list copper as ingredient?
  8. #18
    Aug 2012
    Gilbert, AZ
    I added another gallon of bleach after testing, will test again to see how high CL went up. My fill water is city water, it's on an automatic fill system. Right now the pool doesn't look as green as before, now just really cloudy. I've got a skimmer sock and I'm cleaning it twice a day as it's turning pretty green throughout the day, also have some scum balls that I'm having to clean daily as well. I also brushed the walls today as well.
    As far as the prior chlorine I was using its Leslie's 3" Jumbo tabs. The label only says "Sodium dichloro-s-triazinetrione dihydrate 99%, Other ingredients 1%" So i'm not sure what the "Other ingredients" are. The trichlor was Leslie's Chlor-Brite and the label says "Trichloro-s-triazinetrione 99%, Other ingredients 1%". I discontinued use of both of those when I switched to bleach.
  9. #19
    Aug 2012
    Gilbert, AZ
    Ok, tested last night and early this am and had no change in chlorine. CL was at 21ppm at 8pm and just tested at 645am and was still at 21ppm. Water still very cloudy. pH is 7.6.
  10. #20
  1. cya and other levels
    By dalejanus in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2012, 12:25 PM
  2. Help with getting levels right please!
    By one4irish in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2010, 03:02 PM
  3. CA levels
    By wilcfr in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2008, 12:07 AM
  4. CYA Levels
    By hooeld in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-06-2006, 09:17 PM
  5. CYA and FC levels with SWG
    By mizzouguy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-24-2006, 10:30 PM
