Thread: Totally Lost
    Default Re: Totally Lost
    Thanks to all who helped, Im opening the pool this weekend and will post some numbers. Just need to clarify something here - the chlorine tabs have the stablizer in them(CYA) so as long as it does not get too high Im ok. If it gets hight I need to stop using the tavlets and go with straight bleach. If the CYA get way overboard I will need to drain some water and refill to get the level down. Am I correct? What level of CYA is too high? Is it the high end of Ben's CYA chart?
    Thanks for all the help
    R
    Indiana.
    Quote Originally Posted by Coolflee22
    R
    That's the $64,000 question. I creep up until the chlorine hangs around all day. I'm around 20 right now, but I have a 2 week vacation coming up, so I'll be using the feeder with trichlor pucks while I'm gone. If I was adding CYA, I wouldn't shoot for anything over 30 or 40. Some folks claim that anything over 10 is bad, but I don't know the chemistry well enough to make an educated comment on that. I've just found that at 30 I can put bleach in at night and still have 1.5 or 2ppm the next evening when I test before adding more. Pool is clear, kids are happy.
    faithfulfrank is offline ** No working email address ** faithfulfrank 0
    western New York & Leesburg, Fl.
    As just said, that is the $64,000 question.
    I believe it is generally thought that 30-40 ppm is fine.
    There are those here who keep it higher. Way higher.
    If you do, you just have to know that the higher your CYA is, the higher your Free chlorine needs to be to do the job, because more chlorine is held in reserve.
    Watermom posted a sticky with a chart that will help. I would not freak if your CYA is high, just adjust accordingly. It does go down eventually as water gets splashed out, etc, backwashing, and as rain, etc, replaces it.
    Frank D.
    R
    You've got a good understanding of it. The "normal" range for CYA depends on you and certain characteristics of your pool. As pointed out already, just know that if you raise your CYA to high levels, then you need to keep higher maintenance levels of chlorine to compensate. Most people around this forum tend to stick with 20-40 ppm, and add a small amount of bleach daily. I, on the other hand, live in a very hot climate with full sun on my pool and a heavy swimmer load, so I tend to keep my CYA around the 80-90 ppm mark and only add bleach a couple of times a week. Many people around this forum shudder at the idea, but it works for me!
