Re: Lithium Hypochlorite question
It's more expensive because lithium is more expensive and the lithium hypochlorite is made by bubbling chlorine gas into a solution of lithium hydroxide. Sodium hydroxide is much less expensive so when chlorine gas is bubbled into that solution to make sodium hypochlorite the product is much less expensive.
The main difference, other than price, is that lithium hypochlorite is in solid form, usually granular/powdered, while sodium hypochlorite is a liquid. The other difference is that lithium hypochlorite has 35% available chlorine while sodium hypochlorite usually tops out at around 15% and usually 12.5% for chlorinating liquid or 8.25% for the latest bleach. So with sodium hypochlorite it's more weight to carry. However, the price per FC for sodium hypochlorite is far lower than that of lithium hypochlorite.
In water, however, it's all the same and one does not bleach out vinyl liners any more than the other unless one adds it too quickly in one place with no circulation. If you add any of the concentrated chlorine products slowly over a return flow with the pump running and then lightly brush the area where you added it to ensure thorough mixing, then none of the chlorine sources will be a problem (well, Trichlor granular might still be too slow to dissolve even after brushing, but all the others should mix reasonably quickly).
Generally speaking you should ignore a lot of what the pool industry says, even in the Taylor books. Though some of it is accurate, there's still a lot that's just hogwash.
