Results 1 to 4 of 4
Thread: Suction Side Problems: Air Leaks, Bubbles in Returns, Pump Won't Prime, etc.
    Default Suction Side Problems: Air Leaks, Bubbles in Returns, Pump Won't Prime, etc.
    Jul 2013
    Lansing, MI
    Default Re: Suction Side Problems: Air Leaks, Bubbles in Returns, Pump Won't Prime, etc.
    I went through each of these threads as I have a suction side leak. My problem is slightly different though. I get bubbles out of the outlets and twice now my pump has lost prime. However each time after I backwash it primes fine again. I just changed the sand in the filter a couple of weeks ago. Is it possible that the new sand is working so well that it loses prime?
    I usually backwash every 2 days or more if I'm vacuuming.
    22x35 kidney IG. 1 1/2 hp Hayward, 300 # sand filter, Aquabot cleaner.
    I can't think of a series of causes and effects that would result from your change of sand, and lead to a suction leak.
    Oops. I thought of something.
    It *is* possible that your new sand has lowered back pressure (really, resistance to flow) on the output (effluent) side of the pump. This would in turn lead to higher overall flow, and thus increased negative pressure on the input (influent, suction) side of the pump. That might, in turn, stress a pre-existing weak point in your suction lines or valving, and possibly increase the damage or opening there.
    But, it still comes down to there being a leak in the suction side piping and valving. The sand might have triggered a worsening of the leak, but it didn't cause the leak in the first place, and is not related to the location of the leak.
    By the way, you do not need nor want to backwash every two days or even every time you vacuum. You only backwash when the pressure rises 8-10psi over clean filter pressure.
  1. 30 PSI on Filter, no pressure in returns and pump will not prime
    By deb303 in forum Pool Equipment & Operations
    Last Post: 06-29-2013, 10:31 AM
  2. Possible Suction side leak - booster pump
    By izzicat in forum Pool Equipment & Operations
    Last Post: 06-07-2011, 02:16 PM
  3. Fixing suction side leaks (with RTV silicone)
    By LukeNorris in forum In-Ground Pool Construction and Repair
    Last Post: 07-04-2006, 10:29 AM
  4. Suction Leak Causes Pump to Lose Prime
    By donjoarm in forum Pool Equipment & Operations
    Last Post: 04-14-2006, 12:00 PM
