Re: Sealing Pavers with a roller as opposed to spraying opinions please
I'm planning to seal my new pavers with the same product you used. How long did you wait after the pavers were installed before sealing? How much sealer did it take (gallons per sq-ft)? I have 1200 square feet of deck getting installed in the next week or so. Also, will it be slippery (i.e. dangerous) when applied on a standard 4x8 cement brick paver? Finally, the TechniSeal efforenscence cleaner says it is non-acid based (I think). If it is, would you recommend this over the Behr (acid based) product?
Thanks.
Mike in Oviedo FL
