Thread: ph and alk balance
    May 2011
    Reading, PA
    Default ph and alk balance
    My ph is 7.6 and my alk is 70. If I add baking soda, won't it raise my ph? I was going to add 6 lbs to my 22,000 gal pool. Is this what I should be doing?
    Thx!
    Paige
    In ground, outdoor, vinyl liner, 22,000 gallons w/Aqua Genie skimmer installed in 2008, 1 HP Hayward 2-speed Super Pump and Hayward pro series high rate S244T both installed 2016
    BigDave's Avatar
    Default Re: ph and alk balance
    Why do you want to add the Baking Soda? To raise TA? 70 is a little low by most standards but if the pH is stable, I'd leave it alone.
    May 2011
    Reading, PA
    K I won't add anything. Just thought the alk should be a min of 80
    Thank you for your feedback!
    May 2013
    Concord,ca
    If ch and ph are good wont the rest fall in line?
    Quote Originally Posted by dansdad View Post
    Not necessarily. But you do need to start with those two, BEFORE you try to fix other things.
