Results 1 to 3 of 3
Thread: Sand in Pool
    Jun 2013
    Smile Sand in Pool
    I need some help. Yesterday I changed the sand in my Hayward sand filter and followed all the instructions from youtube and now there is sand in the pool. The only thing I did backwards is that I put the sand back in the filter before the water. I checked and make sure nothing was broken before I added anything. I hope someone can help me.
    Thanks so much
    Default Re: Sand in Pool
    If you are lucky, you just spilled some sand in the wrong place. If that's the problem, you shouldn't have sand CONTINUING to enter the pool.
    If you are not so lucky -- and sand is continuing to enter the pool -- something went wrong during re-assembly. Two common problems are
    (1) Failing to re-assemble the air bleed line correctly
    (2) Cracking a lateral.
    If you post exact make / model of your filter, someone may be able to give more specific advice.
  1. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
    By MikeInMo in forum Pool Equipment & Operations
    Last Post: 05-31-2007, 12:01 AM
  4. Sand in bottom of pool from sand filter
    By nicole12 in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
