Thread: help with startup plan for 12ft intex pool
    BigDave's Avatar
    Default Re: help with startup plan for 12ft intex pool
    The Borax is to offset the pH drop caused by the dichlor - so add Borax with every dichlor addition regardless of the reason for adding dichlor.
    To move from the Intex startup plan to regular maintenance, I'd suggest that you learn the BBB poolcare method taught here - Start by reading the guides and tips on poolsolutions.com and the stickies in the treatment and testing forums here (you probably need to log out to see them). You will need to purchase a Taylor K-2006 or K-2006C to follow this method successfully. If you buy it through the links in this thread the Poolforum get a few shekels to keep the lights on.
    You have time - the Intex plan will keep your pool safe while you figure out the rest.
    Welcome, Congrats, Good luck, and You can do it - it's easier than it seems.
    Jun 2013
    Illinois
    Thanks! I've been reading and will keep investigating. I added dichlor last night but no borax. Today my pH is still 7.6, so I'm thinking I shouldn't add borax unless the pH drops, right? Also, from the simple OT/pH kit (my Taylor kit hasn't arrived yet) it looks like my chlorine is high (though I find this test nearly impossible to read - yellow is yellow to me). Anyway, its a pretty bright yellow - so I'm calling it 3.0+. Is that not safe to swim in? Is there a way to lower it? And should I not add dichlor tonight if the chlorine still looks high this evening?
    If your pH is 7.6, you are fine. Your pH may have been a little to begin with and the dichlor may have just dropped it too low yet. But, continued use of dichlor will cause the pH to continue to drop. Just be aware of that and add Borax if it goes below 7.2.
    Until your kit arrives, you can force your cheap kit to test higher than 3 with a dilution method. It is not super accurate but better than nothing. Go to our sister website www.poolsolutions.com and click on guides on the left-hand side. On the following page, there is a guide called "How to Test Without a Good Kit" that will give you directions.
    With no CYA in the pool yet, your chlorine isn't going to stick around long but at any rate, you can safely swim even if the chlorine is at shock level (which you are nowhere near). If it is a little high, it won't hurt people but you may want to wear old swimsuits. However, I think you'll find that your chlorine level drops faster than you think.
    @ billmi, bellini: membership updated.
    Jun 2013
    Illinois
    Thank you!!
  1. Intex Super Simple Startup and Maint plan questions
    By vinny600 in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-04-2013, 03:09 PM
  2. New Intex pool startup with salt
    By SenderoMan in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-20-2013, 01:22 PM
  3. INTEX 12x36 Owner Wants to Thank YOU for Simple Plan!!
    By southside in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-08-2012, 05:42 PM
  4. Intex pool startup
    By jcwr56 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-28-2012, 09:25 PM
