Results 11 to 13 of 13
Thread: PH/Alk Plan of attack
    Warwick, R.I., U.S.A..
    Default Re: PH/Alk Plan of attack
    Quote Originally Posted by PatL34
    Changes in pool chemistry can take time Wayne, so be patient. The low Alk is definitely responsible for the continuing drop, and as you increase it you will be able to control the pH more easily. Testing the way you are doing is excellent.
    Keep us posted as to what is happening.
    Pat
    Where getting there. I set myself back a bit, I had to top the pool off at lunch yesterday and forgot to turn it off when I left. Needless to say, I over filled it "slightly".
    Anyway. pH is now 7.4 and alk is 70, it probably would have been higher if not for my fantastic memory. Interestingly, with the Cya as low as it is, 10-20, it's holding Cl fairly well. Full sun and hot yesterday and the Cl was still 3ppm in the evening from 6ppm in the morning.
    The white haze is clearing, slowly. It has been 3 days running the pump 27/7. Should it take this long to clear?
    Hang in there, and keep the pump on. Ben's (Pooldoc's) position has always been that AG pool filters are notoriously undersized, so it tends to take longer to filter dead algae out of an AG pool than from an IG.
    OK,
    pH seems to have settled in at 7.6 and I have the Alk to 110. As to the pump/filter being matched; I have a Hayward GM152 sand filter with a Haward UN series 1hp pump. Not sure if this is a good match or the filter good enough for a 12,000 gallon pool. It was all given to me last year.
    Still hazy but getting better...
    Wayne
  1. Going on vacation -- good plan??
    By oscarlet in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-24-2012, 09:51 AM
  2. Plan of attack
    By jrh1010 in forum Above-Ground Pool Construction & Repair
    Last Post: 03-19-2012, 03:44 PM
  3. Cloudy water plan of action
    By wsommariva in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-05-2011, 02:55 PM
  4. The pool is under attack...
    By ShelleyAnn in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-08-2006, 04:10 PM
  5. Newbie needs help. Need a Plan Of Attack To Get This Pool Open
    By NullQwerty in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2006, 02:19 PM
