Since I cant use the search option, I will post my problem.
I had to repair the connection inside the pump , it had a short in it.
Now I am trying to reconnect the motor to the pump, and it is always leaking bad.
I took the pump and the motor outside the pool house, and I am trying to figure out the problem.
As soon as I put water in the pump it's coming out at the black plastic ring.
What is the problem.
