The pool has only been up and running 30 days or so. If I had an underwater camera I could take some pictures. But there is no sign of any activity outside of the perimeter of the pool. The pool was sight was dug down to the hard clay about 6 to 12 inches. I really suspect that they did not compact the sand right because the divots showed up soon after the pool was filled. The divots range from 1 to 3.5 inches deep and the largest is the size and shape of a pro football.
As far as the Nutgrass we have it here in Georgia. The salesman claims that he there was 6lbs of commercial grade Nutgrass treatment put down before the sand was filled in. But now that something that looks like its slightly larger than the diameter of a head of a ball point pen poking up and the blue of the liner is turning white at the tip of the point. I guess we will find out Monday what is going on. The installer is coming to drain the pool and pull the liner back to see what is going on.
