Pool has been up and running for a month now.
FC 4.5
CC .05
PH 7.4
CYA 50
How are the numbers?
FC 4.5
CC .05
PH 7.4
CYA 50
Numbers aren't bad except that you mean that your CC is 0.5 instead of 0.05. How does your water look? Have you let your chlorine dip down below 3ppm at any point? If your CC reading goes over 0.5, you'll want to shock the pool.
Last test before about 1.5" rain the FC was 3 & CC was 0.4 on the 25ml test PH 7.4. Water is looks very clear to me. The only issue is suspend particals that the are out of reach of the skimer. I'm going to shock the pool Wednesday with about 1.75 gallons of 8% bleach from Kroger. That's all I'm doing because the pool is being drained Monday to see why the sand coving has divots all the way around the pool. I also think Nutgrass is starting to poke through the liner. There are quite s few sharp looking pointed spots poking up from the sand. They eather didn't use Nutgrass killer or didn't use it right. We shall see when the liner is pulled back.
Cory, whenever you test with your K-2006 kit, use the 10ml sample instead of the 25ml one. It will save on your reagents.
