Thread: High CH but no problems with pool is lowering CH necessary?
    Feb 2012
    Southern California
    Default High CH but no problems with pool is lowering CH necessary?
    Hi,
    I'm back from last year and tested this seasons water with a net gain of 300 ppm CH. My pool shows no problems whatsoever, the water is pristine sparkling blue. Should I be concerned with high CH before it spirals out of control into scaling problems? My pool is 20k gal plaster with SWCG, and cartridge filter.
    FC: 10
    CC: 0
    pH: 7.6
    TA: 120
    CH: 900
    CYA: 110
    Salt: 3400
    Should I proceed to lime softening when the pool looks fine? I would have to also purchase a vacuuming device, currently only have an automatic creepy crawly.
    20,000 gal Plaster - Hayward Swimpure with 40k+ Cell
    1.5 hp Whisperflo pump - Cartridge filter
    Default Re: High CH but no problems with pool is lowering CH necessary?
    Normally, my tendency is to say, "If it's working, leave it alone".
    But you have an SWCG, and calcium that high is likely to cause scaling. If you've been cleaning your SWCG regularly, and are not having problems with the plates being fouled with calcium, than you may want to leave it alone.
    Of course, you want to make sure you are NOT chlorinating with anything that contains cal hypo (calcium hypochlorite).
    Bottom line: if you have no scale build up on the tile line, and no problems with keeping your salt unit clean, leave it alone.
  1. How high is too high chlorine to enter pool?
    By vaubach in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-13-2011, 06:15 PM
  2. Filter problems...high pressure low output
    By bvanscoy678 in forum Pool Equipment & Operations
    Last Post: 06-15-2011, 09:05 AM
  3. lowering water in vinyl liner pool
    By maxhiller in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-04-2006, 12:31 AM
  4. Lowering Alk in Hot Tub
    By csevel in forum Dealing with Alkalinity and Calcium
    Last Post: 07-04-2006, 11:53 PM
